1 - 3 of 3 Posts
Hey fellas,
Anybody know the stock length of a '68 BSA A65 clutch pushrod. I have one I thought was right but it is WAY too long. If I had the measurement of the stock pushrod, I could cut it to the right length. Thanks in advance!
Trav :???:
TravThrux,
The proper length of aaan A-65 clutch pushrod is 11 1/8 ".
I do not recomend cutting one unless you can harden the end.Without hardening it will wear very quickly.
Lutz
TravThrux,
You could always buy a lenght of silver steel, it come's in 12" lenghts, cut to the length you reqiure then heat the end's untill cherry red and quench in oil to harden.
I use this method when I need to replace a clutch push-rod on any older Brit bike.
H.T.H. Regards TipleGuy :cool:
1 - 3 of 3 Posts
