1 - 7 of 7 Posts
Any chance someone put it there as a joke? The 2 round mounting holes make it look a lot like a type of battery tray, but very different from my '02 tray.
Have you looked under the seat, or is anything dragging or look unsupported?
Definitely not part of battery tray, on initial viewing nothing appears to be amiss and bike runs fine.
Will remove tank before the winter and have a good look, can't see anything like this in the Haynes manual.
Administrator
It's a bracket that held a part of your air injection system, a solenoid I expect it's called. I assume you removed the AI at some point? Now the bracket has fallen off. It can be safely thrown away in that case.
Mine is in a box of junk, because I don't throw things away (I also have 3 broken tachs and a failed regulator/rectifier in that box :confused:). It is the same but different.
Thanks Bonnie Black, that makes perfect sense, the AI system was already removed when I bought it.
Must have taken time to drop off.
1 - 7 of 7 Posts
