My left footpeg snapped off this morning while standing on the pegs. I had just taken off from an intersection that had some bad seams in it from some incomplete repaving work, I stood up to soften the shock and the left peg snapped off and my foot hit the ground and I dropped to the seat. I was accelerating from a stop so I was probably only going 15 mph or so and was able to immediately pull over to a safe place. The peg was found in the road, but the threaded part & nut were not found. I am thankful that I was not riding at speed and standing up to stretch my legs when this happened…very thankful.
Recently, this thread (http://www.triumphrat.net/twins-talk/210252-my-2009-bonneville-se-almost-killed-me-yesterday.html )was posted and it immediately came to mind as I was pulling to the side of the road.
I’ve attached photos for someone more knowledgeable than I to take a look at. The bike has 9700 miles on it, 7500 mine. The bike has never been dropped while I’ve had it, there is no sign of crash damage except for some light scuffs on the feeler (see photo). This looks to me as if the bike might have been set down in a gravel lot resulting in the scratches you can see. When the peg bolt broke, I believe the peg landed rubber side down as evidenced by the rubber scuffs on the top of the peg (see circled areas) with either my foot on top of it or being run over by the rear wheel. Perhaps the dirt that is seen in the pictures between the footpeg and the peg bracket on the bike could be a sign of a gap that opened up from a tip over. The two locating pegs show no sign of distortion or damage – so the footpeg was probably not moving around. However, as I think Propforward commented, we ought to be checking out our footpegs before every ride to see that they are tight and show no signs of any weakness – something I have not done in the past, but will going forward.
So, I think I would conclude that the peg bolt was weakened by a very minor tip over by the original owner, which resulted in what happened today. I think I will try to disassemble the peg, remove the original spot welded “stud” and replace it with an 8.8 bolt with washer and nylock nut. The stud is 8mm, but it appears that the hole in the footpeg holder is slightly oversized.
Appreciate any follow-on analysis of this…
Thanks, Tom
Thanks, Tom
