1 - 8 of 8 Posts
In my attempt to swap out my choke knob, I took off the throttle adjuster bracket the knob is attached too from the throttle body (2 small screws). When I did that, the two tension springs on the small pistons that come out of the TB where the bracket attached popped off.
After much frustration I was able to get them back on and re-attach the bracket, however now the idle does not click into place. It slides all the way out with no 1 or 2 position and wont stay out when the bike is running. It just pulls back in. So basically I have no throttle adjustment anymore.
What did I do? Did some other small part pop out that I missed? There appears to be a few small holes in the bracket that perhaps some other spring-loaded switch locks into to keep it in place.
Thanks!
Vendor
Behind the two holes to the left of where you took the screw out in the photo, there should be a tiny spring and ball bearing. I expect the spring is still there, but the ball bearing will have popped out when you removed the bracket.
Annnnnd, I can't get just the spring and bearing. I have to get the whole kit, which ironically includes the stock knob. Haha! Costs $50, a fee for being stupid...
bearing supply stores often sell loos ball bearings. if not buy a cheep (bicycle) wheel bearing set and rob a ball. should be considerable less than $50.00.
bearing supply stores often sell loose ball bearings.
Indeed, or 78 of them for just over $5 at Amazon:
[ame]http://www.amazon.com/Replacement-Parts-Diameter-Bicycle-Bearing/dp/B005543TKE[/ame]
or 240 of them for CDN$ 5.21:
[ame]http://www.amazon.ca/Diameter-Bicycle-Steel-Bearing-Parts/dp/B00E6Q2JDK[/ame]
1 - 8 of 8 Posts
