Hello all, newbie here! I am expecting a 2019 Street Twin, and am considering getting the British Customs fender elim kit as well as their turn signals for front and rear. Does anyone have any experience with installing all of these parts together, and if so, were you able to do it all with stock wiring harnesses?
Thank you!
Not sure exactly about the BC items, but most likely you should be good. Most of their stuff is quality and plug and play I would guess. The item should indicate what is needed for install. I installed the Evotech fender eliminator on my T120 and it used the stock wiring.
I have the British Customs pan taillight and retro turn signals front and rear on my 2017 ST. Everything was pretty easy to install. It probably took me 2 hours to get everything removed/installed in my garage. My only complaint is the bulbs that come with the turn signals tend to burn out kinda fast.
