Hi all. Would appreciate some help with a 63 6T with Boyer ingnition:
Monday AM, after Sunday eve's two hour cruise around SoCal, the 6T decided to run on left cylinder only. After a couple of minutes idling right cylinder would fire every 15-20 secs for a couple of beats & then stop again.
Battery is good - 12.18VDC with engine off, lights will stay on for ages with motor off. Battery cells are all topped up.
Charging circuit is good : 13.6VDC on idle, 14.1 when revved.
Plugs have been swapped side to side.
Coil leads have been swapped side to side.
HERE'S THE WEIRD PART :
If I pull the right HT Cap (Spark Plug Cap) partly off so the spark has the jump from lead to top of spark plug, the right cylinder fires right up.
Im sure the last (weird) part will make my problem obvious to someone...just not me!
Appreciate any words of wisdom,
Thanks..
Thanks..
