Just did the air box removal, UNI filters. Made my own battery box. The problem is it will not start. I've had it run a few times but will not keep running. So far I've tried 0, 1, and 2 shins no luck. Different pilot screw settings, no luck. Checked for vac leaks and other loose stuff, but still no go. The throttle calbes were adjusted to spec. The settings so far, went with jenks settings, 135 mains, thruxton needles, different shim settings, stock pilot jets 40. Even the dealer said the settings seem close. The bike is a 790 with tors. Any ideas would help. I am searching more threads but no luck.
