1 - 2 of 2 Posts
i ordered down a bonnie T100 adj clutch lever under good information that it would bolt straight on, well on my 2000 TT the diameter of the pivot bolt is totally diff. and its also to long to hold the cable proper so now im stuck with a bonnie lever, wat adj lever actually fits a TT600? looking at all the other triumphs in the show room, they all have a flat headed bolt whereas my TT and the standard bonnie have a 10mm hex bolt and a nut underneath. do they make one that fits a standard bonnie? the fitting looks the same...
you have to pull the pivot bolt spacer out of the stock TT600 clutch lever and put it into the thruxton lever.
Adj lever you need - Part Number T2046021
it should look something like this
[ This message was edited by: SpiritZeroThree on 2007-02-16 20:37 ]
1 - 2 of 2 Posts
