Any help would be appreciated….
-Put the key, no lights at all come on, and obviously the bike won't start.
-Replaced all fuses in case that was the problem…. still didn't fix it.
-Battery was low, turned out the battery was bad.. So i replaced it with a AGM X2power one fully charged.
-New battery still didn't fix the problem..
-Needless to say, i am frustrated and i am not sure what the problem may be.
**PROBLEM SOLVED!! It was SLOT #2 FUSE - IGNITION SWITCH MAIN FEED.**
