BONNEVILLE TORQUE SETTINGS
FRONT WHEEL
Wheel speed sensor bolt 9Nm - 30 torx
Front Brake Caliper Mounting Bolts 21Nm – 12mm
Front brake pad retaining pin 18Nm - 5 allen
Front Wheel Axle 65Nm – 17mm male allen
Wheel axle clamp bolts 22Nm – 6 allen
REAR WHEEL
Wheel speed sensor bolt 9Nm – 30 torx
Rear brake caliper mounting bolts 40Nm -14mm
Rear brake pad retaining pins 18Nm – 5 allen
Rear wheel axle nut 110Nm – 27mm
GEAR SELECTOR SHAFT REFIT
Clutch cover bolts 10Nm - 8mm Threadlock two bolts either side of gear selector arm.
CluClutch spring bolts 10Nm - 10mm
Clutch nut 98Nm - 30mm
Selector Drum 12Nm Threadlocked – allen?
Stopper arm 12Nm Threadlocked – 30 torx
Chain guide bolts 9Nm Threadlocked
CLUTCH SPECS
Friction plates thickness standard=2.90 to 3.10 Service limit= 2.80mm
Total combined clutch plates height = 37.34 to 38.34
HANDLEBARS
Handlebar holder bolts 38Nm
Handlebar clamp bolts 24Nm – 6 allen
SERVICE MISC
Spark plug NGK LMAR8A gap 0.8 to0.9mm 14mm
Drive chain slack 20 to 30mm
Oil drain plug 25Nm
Oil filter 10Nm
FRONT WHEEL
REAR WHEEL
CLUTCH SPECS
HANDLEBARS
SERVICE MISC
Oil drain plug 25Nm
Oil filter 10Nm
