1 - 2 of 2 Posts
I have a 78 bonneville 750 that I am replacing the clutch on and not familier with. I need to know what kind of fluids to put back in it. It is all stock and has the vent tube down the rear fender and looks like it has an oiler from the engine side. The owner who was my bossman just passed away and I want to get it ready to ride to his service. So any help will be greatly appreciated and any tech tips on this. thanks
150cc's of 20/50 SG rated motorcyle oil in the primary case. Same thing you should be using in the engine. The engine and primary share oil from 1970 on. Doesn't seem like much oil in the primary, but the chain only needs a mist to run in. You don't want to saturate your clutch disc's.
1 - 2 of 2 Posts
