Hey guys,
I believe I’m having an issue with my 2014 bonneville t100 but I’ve not been able to find specifics about this topic outside of a few threads that didn’t seem to have a concrete consensus.
I have an oil temp gauge from newbonneville, which I got because I suspected the bike was getting hotter than it should, and I am routinely seeing temps of 200 F (93 C) on 30 minute rides with ambient temps of 40-60 F (5-15 C). Yesterday I rode for about 40-50 minutes with ambient temps of about 70 F (21 C) and the gauge hit 240 F (115 C). I believe I’ve seen it go to 250 F (120 C) before but I cant remember the specifics. I’m usually on the highway for about half the time and low traffic city driving for the other half.
I currently have the TTP tune 2, Tec 2-1 exhaust, DNA filter, breathe intake, Airbox baffle delete, o2 sensor delete, AI delete. I was seeing these temps prior to those mods.
I recently checked my valve clearances and all but two intake valves were in spec and those two were .02-.04mm loose so i left them as is. The only other factor I can think of was that when I was installing the intake filter I saw oil in the airbox - I cleaned it out and made certain my oil levels were correct but have since seen trace amounts when I checked. Spark plugs look good and the bike runs great otherwise, but I never really ride for longer than 45 min or so. I get about 40mpg.
Hoping someone has some insight into whether these sorts of temps are acceptable, what to check for if not, and any possible causes.
Thanks in advance
Thanks in advance
