The T100 had the speedo/tach combination, but you might need the short wiring harness from the headlight shell to the gauges unless you have the three wires already there. If you need the bracket and tach, PM me as I have them.Just bought a 2006 Bonneville. It has just a speedometer. Was the Thruxton the only model that also had a tach? If so can it be added to the Bonnie? Are the wiring harnesses the same on both models?
Did you get my last post,The T100 had the speedo/tach combination, but you might need the short wiring harness from the headlight shell to the gauges unless you have the three wires already there. If you need the bracket and tach, PM me as I have them.
Yes, I got it. There are actually two grey/white faces for this bike. The differences are subtle and you do have to look at it to notice. I am trying to get a couple of photos to send to you.Since I submitted my question I discovered there was a kit offered from Triumph.
Just have to find out if still available. I am discovering a lot of dealers listing unavailable or obsolete parts. A little frustrating.
Haven't gotten into the headlight yet. Will look this afternoon or tomorrow AM latest.Yes, I got it. There are actually two grey/white faces for this bike. The differences are subtle and you do have to look at it to notice. I am trying to get a couple of photos to send to you.
Were you able to establish if the "extra" red wire from the igniter to the plug in the headlamp shell was present?
I don't have a manual of any kind as yet. On my list.Yes I got it. If I can get one of my friends to take some photos of what I have then I will send them to you.
It might be easier to remove the saddle to see if the wire runs between the ignitor and the headlamp shell. If you can get a good close up of the ignitor plug then I should be able to tell.
Do you have a Haynes manual? They are invaluable when working on these bikes. I inherited the Triumph workshop manual but I wouldn't recommend it.
Interestingly, I am trying to track down a pair of early Thruxton gauges as I prefer the white face!
Your other option is an electronic speedo mounted centrally. Can be made to work with a mechanical speedo drive.I do not care for the offset mount on the speedo. Like more symmetry.
I prefer the dual gauge symmetry too, it has looked right and balanced for decades.I don't have a manual of any kind as yet. On my list.
I also have a recently acquired 2016 Thruxton. Both bikes kind of fell in my lap after searching for a long time.
If the tach that you have is close in appearance to my speedometer then I think we are golden.
I do not care for the offset mount on the speedo. Like more symmetry. Maybe I'm just a little wacky.
There have been several posts regarding the wiring on the tach and it all sounds pretty straightforward to me. I will start in the headlight and,if needed, work back from there.
Ok got into the headlight . No unattached red wire there.Yes I got it. If I can get one of my friends to take some photos of what I have then I will send them to you.
It looks like the "extra" wire is there. The next step is to locate the plug in the headlamp shell, that's the one where the wiring from the gauge cluster (warning lights etc.) plugs into the main harness. You should see one red wire on the main harness that does not go up to the cluster, that's one of three that you need for the tach. The other two are a switched feed (green with a red tracer) picked up from the oil pressure and neutral lights and a ground (brown but changes to black), picked up from the instrument light and high beam warning light ground.So after further research I believe this might be the igniter. Am I correct? View attachment 802365
Should be good to go on that based on what I found earlier.It looks like the "extra" wire is there. The next step is to locate the plug in the headlamp shell, that's the one where the wiring from the gauge cluster (warning lights etc.) plugs into the main harness. You should see one red wire on the main harness that does not go up to the cluster, that's one of three that you need for the tach. The other two are a switched feed (green with a red tracer) picked up from the oil pressure and neutral lights and a ground (brown but changes to black), picked up from the instrument light and high beam warning light ground.
Interestingly, it doesn't show the "extra" wire in the wiring diagrams but it is there.
Not necessarily. The wire runs up to the plug in the headlamp shell, but there may not be a corresponding wire in the short harness that plugs into it and goes up to the gauges. Does this make sense? It's a bit difficult to explain until you look inside the headlamp. Count the wires on the plug in the main harness (11) and compare that with the number of wires in the short harness plug (10 or 11). Either way, the hardest part of the wiring is done.So the connector is already in the housing where the indicator lights are?
There is a red wire on the side of the connector going to the gauge and indicator lights. Pulled back sleeve to confirm.Not necessarily. The wire runs up to the plug in the headlamp shell, but there may not be a corresponding wire in the short harness that plugs into it and goes up to the gauges. Does this make sense? It's a bit difficult to explain until you look inside the headlamp. Count the wires on the plug in the main harness (11) and compare that with the number of wires in the short harness plug (10 or 11). Either way, the hardest part of the wiring is done.
