I put thruxton length rear shocks on my 2013 T100 Bonneville, which raised the rear a little. Makes the tip in noticeably quicker.
Hey Tornado, I'm not aiming my response directly at you... but I'm using your post to address the various "cause and affects" of the two main ways to alter the rake and trail of the Bonnie's standard set up... lowering the front or raising the rear... or if you really want to get snappy... doing both...
If a person likes the seat height and feeling of the "center of gravity" of the stock settings, the best and easiest way to "quicken" the steering is to raise the fork tubes between 10mm & 15mm in the yokes... this will slightly decrease the rake and trail.. but it does it enough to aid or "quicken" the turn in... This will not affect seat height, the "center of gravity" feel or any suspension function or feedback... it's easy peasy... works great, costs nothing and can be returned to the stock set up in a matter of minutes if you want... and no... within the context of a 10mm to 15mm move, it does not negatively affect the high speed stability... Lots of folks have done it this way for years... myself included...
Raising the rear... this can be done via longer shocks and/or larger than stock diameter tires... 140/80/17's for example... work great on the Bonnie and will raise rear by about 1/3 of an inch due to their larger diameter (26.5" vs 25.75")... Going to the Thruxton or Scrambler length shocks nets you around a 1" rise... These alter the stock set up by raising seat height and the center of gravity of the Bonnie... some... not a lot... but it does affect it.... If you have a long inseam, these can be a good change... for others... ???? To me, the downside of raising the rear to affect the rake and trail and quicken the steering a bit, is in the case of longer shocks is: the cost and the altering of the seat height and the "ass in the air" look it adds to... and of course altering the C of G... Going to a larger diameter tire is purely down to buying a different size of a disposable/wear item... though going to a larger diameter tire does affect the final drive ratio a bit... going with the 140/80/17 has the effect a bit like adding a tooth to the front sprocket...
As the old saying goes... "there's more than one way to skin a cat".... for me... and this is just me... if you want to "quicken" the steering a bit... it make so much more sense to simply move the fork tubes up in the yokes a bit...
Just my 2 cents worth...
