I fitted a centre stand from triumph, not sure if its the same, but the instructions are at www.triumphinstructions.com, part number a9900462. I found it easier when fitting the spring to put the bike up on the centre stand first, then stretch the springs on. Good luck.
Sent from Gary's iPod touch using MO Free
I have the tec center stand on my 2012 T100. Instructions are a bit confusing. Remove that cannister thingy under the bike and it will make much more sense, and alot easier to install the bolt on the right sight mounting plate.
I was able to attach the spring with the center stand tucked up.
One problem i did have was the the sidestand rubbed the centerstand, making it difficult to put the side stand down. Took the dremel and after a few minutes had removed enough from the centerstand to that the sidestand would move freely. Some spray-on bed liner (great stuff) and good to go.
I didn't have any problem getting the Tec stand on. I have the same bike as Taxbiker and had the same problem with the side stand and like he said, an easy fix.
