Bike starts fine, idles fine, revs fine but shuts off when I place it in gear. Thoughts?
Sent from my SM-G973U using Tapatalk
Kick stand switch?
that's definitely the first thing to check if the engine cutting out completely, and if nothing happens when you press the starter with the bike in gear and the clutch pulled in it'll be the kickstand switch.
It's still the plunger type on the daytonas so try spraying some contact cleaner if you have any and flick it in and out.
On the other hand if the bike is stalling then maybe it's your clutch adjustment.
Here's another vote for looking at the kick-stand switch. If the bike lurches and then stalls when you put it in gear, that's the clutch adjustment.
