Three weeks ago I parked my carbed 08 Bonnie after a nice ride with some mates. She was running great, not even a hint of anything wrong, ever. Two weeks ago I went to start her up for a quick ride and she wasn't having any of it. Sounded like crap, almost like it was firing on one cylinder, when I try to give a little gas it runs worse and then dies.
After some long searches on the forum, I see that it could be a spark issue or a fuel issue so I start checking the spark side. Both cylinders get hot so I know they are both firing. I checked for spark on both and it is good, (changed the plugs just in case anyway). Both spark plug wires measure fine. Dumped the old fuel out and replaced with fresh fuel, no better. Changed the coil, no better. Cleaned the inline fuel filter, no better. Started the bike and sprayed starter fluid onto the carb filters (which by the way I cleaned and are as new) and no difference. Checked the carb floats, slides ect., all look in excellent condition. No rodents in my exhaust. I even borrowed a friends Ignitor and tried it on my bike but alas, no improvement.
So tonight I took the carbs off and took a peek at the valves. Now I am not a mechanic, but something tells me that built up tar-like material on your valves is not good. This stuff looks like oil and I have never seen anything like it. Could it be coming from the cylinder head? Maybe from the radiator pumping into the cylinder head and then down onto the valves? I cant imagine this would have happened as a matter of normal running, even if I was running very rich. I know I was not running rich bc my dyno run confirmed this.
Has anyone seen this before or have any ideas what could be causing this? You can also see from the pictures that this stuff has found its way into the carbs. It is sticky and to me looks like it could be oil. Both sets of valves that I can see look exactly the same so I only loaded one picture. So, what is it? How did it get there and what can I do to fix it?
Any ideas would be great. Thank you.
