1 - 3 of 3 Posts
I like being seen. Something that I put on a bike that doesn't a lot of rear lighting, besides reflective tape and stickers is pictured below. A multi function tag light. They are available from several sources and I've had good service out of the ones I've purchased. The one pictured has a tag, running and brake light as well as turn signals built in. They are fairly easy to wire, just tapping into your bikes wiring for the various functions. The one pictured uses LED lights so it has little draw on your bikes electrical system. Just one more way for the cagers to be aware of you and what you are doing without changing the look of your bike significantly.
1 - 3 of 3 Posts
