1 - 20 of 29 Posts
Hello, I've done some searching on here but have not seen what I'm looking for. I mostly do straight line commuting on my S3 with the occasional twisty. I'm looking to replace the stockers does anyone have any recommendations and where to buy? Also the dealer quoted me a install labor charge of around 175.00 does that sound right?
Appreciate the info...
That sounds very high, to me. I change my own tires, but, I think most places here charge about $20/tire if you take them the wheels and $40/tire if you ride the bike in to the shop. I'd suggest you go to a shop that sells a lot of tires, rather than a Triumph dealer.
Avon Azaro 45/46 ST. I've got almost 3K on mine and they still look and grip like brand new. I ride mostly twisties with about an hour of straight line freeway riding to get there.
I don't push her too hard, but I'm expecting to get 8-10K out of this set...
They're not cheap, but they are great tires...
I like the Pirelli Corsa lll much better than the Michelin's, But, $175. to change the tires out sounds outrageous!
For that kind of money you can just about buy all the tools needed to remove your own tires.
There is a rear stand on ebay in the Triumph section for around $80
If you decide to remove your own rear wheel, Remember, It takes a lot of @ss to break that big nut loose, I had my girl sit on the bike while it was on the floor and hold the rear brake while I broke it loose with an extension on my breaker bar, That was the hardest part.
The front, I used a floor jack, shimmed in places with s***** wood so I didn't crush the headers... Keep it on the rear stand to keep the bike vertical.
At first on the front, I used a standard sport bike rear stand with the rubber swing arm lift pads pushed in close enough to lift at the front brake caliper brackets, worked great at first but the forks got twisted on re-assembly and I couldn't get the axle back in, So I went to a floor jack to get the front wheel back on.
Discussion Starter · #7 ·
Thanks for the opinions so far
The dealer quoted me 70 an hour as the labor rate One hour for the front and one and a half for the rear.
I can't locate the Conti's anywhere online the dealer quoted me 180.00 rear and 130 for the front on those.
I look into the others mentioned.
I take apride in doing my own work but I would rather have this done.
The dealer's trying to bend you over. Those time estimates are absurd. Also, they're backwards; it takes less time to change the rear than the front.
So far, I've tried BT020, D220, Metzler Z6 and Michelin Pilot Roads in the "sport-touring" category, and they all seem to wear and handle about the same. The Pilot Roads turn in a little slower because of their more rounded profile, but it wasn't a bad thing really, just different.
Since you're in the Woodlands, you might consider dropping your wheels off at Cycle Gear on I-45 near West Road. Their prices are significantly better than what you were quoted and they only charge 20$ to mount and balance, but your wheels do have to be off the bike.
+ a gazillion!!! :hammer: Find yerself a new dealer, those prices make me go into convulsions!!! :( My dealer has changed my rear before for $25, and that was me riding the bike there. The most you should pay if your wheels are on the bike is $60-70, and that's even ridiculous to pay!
Joh Bloor Special
That is theft, pure and simple. My tyre guy will fit both front and rear in less than an hour. Do as Curmudgeon suggests and go to a tyre (tire) specialist.
also like to add that I got charge alot for the tire install.. $130 for front and rear, and I rode the bike to them too. This shop is in Durham, NC. :mad:
So any recommended shops in the Raleigh, Durham, Cary, Apex area??
My 2 cents worth...
Conti Sport Attack on front and Road Attack on the rear. I ordered from MotoXOutlet. Great prices. Installation was $90 for both after I'd taken off then taken in the wheels/tires. Seems like dealerships have decided price gouging is a legitimate business practice.
The latest edition of Sport Rider has a big comparison article on sport-tour/sport/DOT race and slicks from Michellin and Dunlop.
The lap times were somewhat slower on the sport-touring tires, but not bad. Technology has come a long way and unless you're doing track days, the sport-tour makes sense.
That said, I have the Pilot Powers on the triple and Sponge Bob.
1 - 20 of 29 Posts
