1 - 2 of 2 Posts
Hey Guys
I found a belly pan for my RS. But the seller did not know what year it fit. You all told me that the 99-01 was slightly different than the 02-04.
Its part number A9701128-FA (FA=Yellow)
- X
Sounds like that is the earlier bellypan.
The later model 02-04 Gen 2 motor is Triumph Part No. A9708065-FD as far as I know, but I could be wrong so check it out.
It will fit from the earlier model (gen 1 to gen 2 motors) but if it is a gen 1 bellypan you'll need to cut out a little bit for the alternator cover for the gen 2 motor.
Wouldn't be too hard with a Dremel and some patience (Triumph part no.A9701128-PAT)
Make sure it has the tabs, nuts and hose clamps.
Good luck :)
1 - 2 of 2 Posts
