1 - 3 of 3 Posts
RidersDiscount.com has Bell Star Cerwinske Limited Edition helmets in stock and ready to ship. This helmet features a shell made from a carbon fiber composite formula to yield a lid that’s lighter than Bell’s already light Star Helmets for exceptional comfort and reduced stress on the neck. The outer shell is specifically shaped to cut through the wind with minimal buffeting so as to provide a trouble-free view of the pavement ahead. Inside the Snell M2010-certified helmet, a fully-removable liner (down to the chin strap covers!) is fitted making it easy to keep the helmet fresh. For street riders, Bell has even included a provision to remove sections of the ear pockets to facilitate the installation of speakers from a motorcycle communications system. Ventilation is addressed by a series of adjustable intakes at the front of the helmet on the chin bar and above the eyeport. These intakes can be easily adjusted with a gloved hand and work with channels molded into the EPS liner to deliver fresh, cool air to the skull and then exhaust it out the back of the helmet for maximum comfort.
These are not yet available on our website - for more information on Bell Star Cerwinske carbon fiber helmets, call Mike at 866.931.6644 ext 804 or send a note to FORUM at RIDERSDISCOUNT dot COM with BELL STAR in the subject line and we’ll get back to you right away. MSRP $649.95
The Bell Star Cerwinske Limited Edition helmet with a carbon fiber shell.
Bell carefully reversed Mr. Cerwinske’s design with the carbon fiber acting as the black etching of the man’s famous design.
The easy-to-grab silver lever seen here is part of Bell’s 3Mode Shield system. It can be adjusted to lock the faceshield closed, crack the helmet enough to allow extra air to flow over the face or be unlocked for quick changes or to flip to visor open.
Bell’s Velocity Flow Ventilation System exhaust vents can be found on the back side of the Bell Star Cerwinske helmet to pull warm air out of the helmet as you ride.
Discussion Starter · #2 ·
Bell Limited Edition Carbon Fiber Helmet
Adjustable intake vents on the front of the helmet can be found on the chin, above the eyebrows and on the forehead.
Keeping your Bell Star Carbon Fiber helmet fresh is easy with a fully-removable liner included as standard. Notice also the removable chin skirt which helps keep cold air out on days when the weather is less-than-favorable.
This helmet is designed specifically to be stable at speed with no lift and no buffeting thanks to the aerodynamically-sculpted shell.
Every Limited Edition Bell Star comes with this nice, protective carrying bag.
Bell Carbon Fiber Helmets
We have a few of these limited edition Bell Star carbon fiber helmets yet to go here at www.RidersDiscount.com - they’re all brand new in the box and ready to ship the same day you order!
Having been developed and tested at Bell’s own US facility, every Bell Star Cerwenske carbon fiber helmet is Snell M2010 certified and DOT approved.
We’ve found the Bell Star’s interior to be as comfortable as it looks.
1 - 3 of 3 Posts
