I ordered some BC Predators and have to rejet. Am I correct in that both the main and pilots simply screw out and screw back in - no crap will fallout and cause much mental anguish? No hidden "oh ****" type things?
Thanks, Prop. I did read that. I wanted to make sure the process was the same for the pilots as well as the mains. BTW - I saw your video on the BC website re: the Preds. Good stuff!
Thanks,
The pilots are smaller, and recessed into one of the casting ports, but if you use a small enough flat bleded driver bit you can still get up there without taking the carbs off, though some folks like to do that anyway. As I recall I actually popped mine off to do the pilot jet, but it was easy because I was taking the airbox off.
