What you using??? im on stock items
So are they wider and/or higher than the stock bars?Here are some pics. Hope this works.![]()
Great - thanks for this info. Do you have heated grips on yours - and if so, any problems? I've heard aluminium doesn't work so well with heated grips.They are a little wider and more straight (less pull back). I dont know the dimensions of the oe Triumph bars, but here are the dimensions of the ones I put on. I will say that I was concerned that with a much lighter bar and no bar ends I would get some vibes. Not the case, very happy with this set up.
YAMAHA YFM 660 RAPTOR 2001-2005
OE BAR BEND :
Dim A Dim B Dim C Dim D Dim E
785 140 105 155 100
J-Dub
No heated grips. I've heard the same about aluminium. If I get that cold I'll use heated gloves.Great - thanks for this info. Do you have heated grips on yours - and if so, any problems? I've heard aluminium doesn't work so well with heated grips.
Neil
