So after blasting away on great, but bumpy, roads in the mountains I discovered that one of the bar end weights are gone. Inside there is a cylinder-shaped thingy with threads in the middle. Is this a part of the missing bar end weight or a part of the handlebars? If its not supposed to be there, how to get it out? :)
Alright, thanks. So for a new bar end weight I'm looking for something without the expanding part? (Newbie question but my previous ride was from '72 :)
If you see ones you like that will accommodate a screw that will go into your insert, you can just throw the expanding part away. Or there are some out there with just screws and spacers.
Thanks a lot! Unfortunately my nearest dealer is 400km away, so online ordering is a must :) Maybe I should take this opportunity to order some bar ends ;)
