So I really like the MassMoto Mohave exhaust on my 04 Bonneville, but I'm stuck between "baffles or no baffles". It's a bit too loud without baffles, and a bit too muted with them in.
I'm hoping for a middle ground (call me goldilocks) but don't want to ruin the baffles. I butchered a Zard Low Cross baffle one time, and trying to source a replacement was near impossible...
If I drill some holes in the end cap of the baffle, will that likely give me the middle sound ground I'm looking for? If so, I'm guessing that holes roughly the same size is preferred?
It seems straight forward to me, but wanted to give opportunity for someone with more experience, or more knowledgable about baffles and back pressure to chime in before I start my usual "hack first and ask questions later" MO... :grin2:
My guess is that if I hate the mod, I could always weld a round plate over the new holes to be back at stock?
Thoughts?
That's the sound!
I wouldn't hesitate. Start with some small holes, and try to deburr them as much as possible. Then work your way into perfection. As you said, it would be easy to reverse.
Charles
Saw the bigger hole theory too late.
Just got back in from the garage... Started with 6 3/16" holes. Wasn't bad, but went to 10 holes and that's better. It sounds real nice "in the driveway" but of course I'll have to re-evaluate after a real ride with helmet on and such.
Thanks for the wisdom fellas!
