Occasionally when I decelerate in gear ill pull in the clutch and blip the throttle. Every now and then the bike makes a pop sound ranging from a backfire to the sound of a paddle hitting a ping pong ball. I thought it was from the back but I rode the bike without a helmet its definitely coming from the front. When I blip the throttle the bike pretty much bogs or dies for a hair of a second when the pop happens. So the engine stops firing, makes the pop sound, jerks a little, and fires right back up again. When the pop happens I can hear the throttle bodies actually slam shut due to absence of running sounds.
I'm wondering what it could be before I take it to the dealer, they can't recreate it and my time is wasted.
This happens to me as well, only in neutral or with the clutch pulled in (disengaged)
Though I just get a pop. Engine doesn't die or anything.
Identical to what happens to mine. No stall or die, I worded it weird. It's a hesitation. Just a backfire but through the intake when I blip the throttle.
I seem to be having a similar problem with my Bonnie. I have tried several solutions but have not been able to correct the problem. I even had to replace the rubber connecting hose from the throttle body to the head because it burst. Did you find out what the issue was?
