1 - 12 of 12 Posts
Hi Folks,
I seem to remember a discussion on avons failing 10 years or so ago. Something to do with a sticker that caused damage. Tonight I removed an Avon road rider from my Suzuki and was surprise by what I found inside. A load of rubber granules. The granules are softish rubber that breaks when squeezed hard. There appears to be what was a foil sticker in there. Tyre was 8 years old and was almost, but not quite, touching the wear indicator patches.
Ring a bell to anyone?
Anyone seen this before?
Gesture Finger Wood Wrist Thumb
Automotive tire Tire Tread Synthetic rubber Grey
Plant Organism Font Tree Fruit
Insect Arthropod Gesture Grey Finger
When i fitted an Avon Roadrider, there was a sticker inside like that one. After 4 days use, the metal sticker cut the inner tube. I now make sure there are no stickers inside any tyre fitted with a tube. No rubber balls in the tyre but i have seen that happen in many car tyres.. There is a tyre balancing system that uses small balls to do the balancing. Not tried it though
I was thinking balance balls too, but I doubt they'd work in a tubed wheel as the tube wouldn't let them move.
It might have been me posting the label issue about 10 years back. I have found the Avon to be a really good tyre except for this fault. Maybe if the label was paper it would not happen at all but my label was aluminium foil. On a tubed tyre, the balance balls would be inserted through the valve core into the tube.
I’ve seen these little balls a lot in off-road tyres which run tubes at low pressure (1 Bar or less) to improve grip. I think it’s just the friction of the tube moving against the carcass rolling up tiny balls of rubber.
When my boys used to fit tyres on cars, the rubber balls were often found. They had not been put in there but i still dont know how they form in the tyre.
Eight years is old enough to replace, anyway. I had Shinkos that developed trash inside and blisters in the tread. Must not have been fully cured, or couldn't handle the GL1800 they were "designed" for.
Discussion Starter · #10 ·
Seems to be the experience on the web, often seen but folks not sure how it happens. I dropped Avon a line and will keep folks posted if I get a return.
This was on my Suzuki so was in tubeless tyre use.
Discussion Starter · #11 ·
Got a quick reply from Avon's website form, asking for me to send photos and they would get back to me in quick succession.
Since I sent the photos they have all gone dead. Couple of weeks and a couple of reminders.
Seems I hit a nerve....
Reminds me of an almost new Michelin de-laminating, after a lot of chasing they collected the tyre as evidence & then totally blanked me.
1 - 12 of 12 Posts
