1 - 15 of 15 Posts
I never slid before on wet pavement but just slid out on 3 month old asphalt sealant that was covered in overnight rain water a week after a snowmelt. No ice on roadway I assure you, temp was 55 degrees. I looked up asphalt sealant: awful stuff, no friction.
is going dark side a solution?! My tires are Michelin PR2s, excellent tread, inflated at proper level. Low sided at 30 mph around bend, zero warning. I have to ride in this road in front of my house.
Driftless Admin
Well, think you'll have pretty universal agreement that you don't want darkside on a speed triple. :) Not sure we've ever had universal agreement on anything around here before, but this may be it.
Real lousy part is that once you're nervous about slipping, you tighten up and the chances of making a mistake go up.
Just need to keep a light hand on the bars and go slow I think. Someone else may have better ideas.
Driftless Admin
I was running fast down this two-lane between Yellowstone and the Bighorns a few summers ago. Under a heat dome, certainly upper 90s. I hit a tar snake 6 feet wide, all across my lane. Someone had done a half-assed patch and just laid down tons of that ****. So thick and sticky it tried to rip the tires from my rims.
To this day, I am still working on unpuckering.
Discussion Starter #8
Rain never bothered me before. Now I'm spooked. It was just a wet rain on the road, there was no wet tar, the stupid roadway was slick as ice. I just don't get it because I ride in all weather on all kinds of roads, never slipped on rainy surface. I trust those tires but something was different and now I'm thinking car tires for increased contact patch. It sounds crazy!
Asphalt sealant is the devil's surface I tell you.
I have often thought that some poor biker will get hurt or worse on all these asphalt repair sealants. I do not like law suits but if some county has to pay out big $$ maybe it will change. A little grit like fine sand could be added to the sealant.
I use pr4's and get decent life and excellent contact in wet weather and yes I put them on my speed triple.
I used to commute on a road that's surface was like ice when wet. Thankfully, just a short section of it. Unfortunately, it was a downhill to a stop sign. I slid a lot of times, but stayed straight and never fell. I still don't know what was different about that surface. I'm just glad I didn't go down discovering it.
That was my preferred tire on my Speed Triple. There is a lot of oil in the sealant. Add water and it gets slick. The worst is that stuff they seal asphalt cracks with...tar snakes. There you are... riding nice and easy on dry pavement...you go to lean into a corner, when... quite suddenly...tar snakes!
... And your front tire suddenly decides it doesn't love you any longer. Summer on Three Twisted Sisters was full of them.
My office just put asphalt sealer in the entire parking lot.
Thankfully, I was in the cage fist day it was wet... Almost went down just walking away from my truck.
That stuff has NO grip when the slightest bit of moisture gets on it. Even on 4 tires you slide around a lot.
It should be outlawed for safety reasons. I honestly have no idea how something so slippery ever got cleared for use on roadways.
Sent from my E6810 using Tapatalk
A few years back, I worked at a MSF riding school owned by the local Harley dealer. The range was a large lot behind the store. It was resealed and we spent a lot of time painting the new course lines. It looked great. The first time it rained, rider coaches were lowsiding while demonstrating exercises during the BRC classes. Not a pretty sight.
They then recoated it with sand mixed in. We spent the rest of that season blowing and sweeping a lot of sand off the range.
That was my last season there. I don't know how long it took to be safe again.
Lawsuits will not scare a county into making any useful changes. I work for a county Law Enforcement Agency. The agency, the county govt, and the individual can all be sued. They throw just enough money at the person to make them go away. The crackheads are happy and smoke up all their money in short order.
Consider there are far more crackheads than registered motorcycle riders. You see where this is going, don’t you?
1 - 15 of 15 Posts
