1 - 7 of 7 Posts
Has anyone put an Arrow 2 into 1 exhaust on a 09 EFI Scrambler with the dealer map downloaded ? If so how did it go and was there a big difference in weight reduction and performance ? Was it worth it ?
Has anyone put an Arrow 2 into 1 ....... Was it worth it ?
"worth it" is valid only in the eye of the beholder. I've got 2 into 1 on order and will have some black ceramic coating done(header and heat shields) prior to installation. Should be about 2 weeks out, I'll let you know how it goes.
I've got a full Arrow 2into 1 system and map on my Datyona 675 and am VERY pleased with the results.
I've got a full Arrow 2 into 1 system and map on my Datyona 675 and am VERY pleased with the results.
:LaughAtYou: You are aware that a 675 is a Triple, right? :BigEyes:
Cheers
Jeff:motorbike2:
Thinking about doing the same thing. Did you get the black Scrambler over the khaki green? Only seen the black, dealer getting a green in in Feb.
Cheers
Jeff:motorbike2:
Jessss, I thought it was kinda fast 4 a twin. :D
2 into 1 Scram system went to the ceramic shop today. Hope to have ot back by the weekend., then to the dealer for installation and re-map.
1 - 7 of 7 Posts
