1 - 8 of 8 Posts
So I am in need of changing out the sprockets and chain. Sprocket looks pretty simple so this post has everything to do with changing out the chain. I am hoping/would like to do it myself. Has anyone ever changed a chain before on their bike? If so do I need a chain breaker/riveter to do so? Any tips or suggestions on what breaker/riveters are good out there to use? Any good suggestions on doing the task at hand. Thanks ahead of time.
+1, on what Brad said...
Remember, the term "chain breaker" really gets people into trouble. You'll need to grind down the riveted pin on one of the links with a dremel tool or die grinder prior to using the "chain breaker". If not, you'll break the tool...
X2 on what everyone else has said. Another thing i'd like to add, which you may know. My T595 required a 36mm socket to remove the front sprocket nut. Thats a little larger than the standard issue. I had to order one to do the job.
Thanks for all of your input. I have on last question involving the chain. I spoke to someone the other day and had mentioned that I make sure I put the chain on in the right direction. Does it matter which way the chain goes on or was all in his head?
All in his head. He might be referring to a clip type master link which you wouldn't be installing anyway, you'll use the rivet type. The clip always gets pointed with the rounded part heading in the direction of chain travel. Or picture it as a fish, the fish always swims upstream.
1 - 8 of 8 Posts
