I was happily working on my bike when I noticed this:
This is the top sub-frame mount for my 05 speedy. Note that it has two different holes in it, and it can pivot on the lower bolt. Moving it to the other hole would have the effect of raising the rear by half an inch or more. Why do you suppose it has this capability?
I'm stumped, unless it's a leftover from back when they were considering making a 1050 Daytona- which they clearly are not at this point.
Any thoughts on this?
I don't know if this helps, but I have no idea why there are two holes there. That weld looks like it was done by hand too which is kind of surprising.
Hmmm hold on a sec while I check mine.... This is under the side pannel where the tubing is connected to the frame? I didn't take my side panel off but I can feel the other whole. Maybe its there for really tall people as an adjustment. I can see why the weld is ***** though... it's generally not seen. Niice color by the way.
Joh Bloor Special
I doubt it is there for an adjustment. If the second hole was used the side covers would not fit.
Perhaps it is a generic subframe and is used on other models such as the Sprint or Tiger.
