Hi
Where do I start? I'm hoping that you wise guys and girls out there can shed some light on a misfire problem.
I have a 76 bonnie, good condition having been rebuilt a couple of owners ago.
The bikes been running fine plenty of power and starts first kick (by the way I'm back into biking after a lapse of many years having been into classic triumph cars.so understand mechanics and electrics)
I parked it up in the workshop and two weeks later it started fine but I could straight away feel, hear a misfire. Now the only thing I did in that two weeks was replace the steering lock, which meant removing the headlight assy.??
Its not an intermittent misfire, it seems to be be regular.
Ive renewed the plugs, and leads. it has newish 12v coils, which ive put a meter on and all seems ok.
It has boyer mk3 ignition which ive checked out the wiring connections and using the "OZ Bloke" electrical check run checks on the ignition unit. (great document)
The battery holds its charge and has 12 to 13 v. Ive had it on trickle charge for days.
I can see a "sparx" alluminium finned unit bolted beneath the battery box with green/white, green/black leads coming from it.Not sure what this unit does, replaces rectifier?? possible fault??
It starts first kick, no choke. (The carbs are new) wont idle.
Ive not checked any timing, why would it move??
I havent checked valve clearances (was running fine,)
When Ive started the bike I think the misfire seems to be more left side, bit of unburnt fuel smoke coming out.
Ive run out of ideas
I would appreciate some questions/advice to trigger off the thought process.
regards and thanks in advance.
Mark
Mark
