99 Legend, Keihin carbs. Removed & cleaned as per all your help. Thanks much. Bike started and ran ok, but is slow to return to idle when throttle down. In the help thread, it was suggested 2 1/2 turns on the air mix screw. I removed my carbs again for another look and would like to try this setting, however, these carbs have a blank plug over the screws, probably to keep boobs like me from messing with them. Whats your experiance with this? Should I leave well enough alone?. I would like to at least get to this to run some cleaner and air pressure. How do I remove the blank plugs without damage?
Again, thanks so much for the help. The Haynes manual leaves a lot to be desired.
Terry D.
Terry D.
