Hi Guys,
I have a problem. I recently bought a Harris T140. 95% stock and never messed with. It did had an idle problem and the carbs flooded the firt time i went for a drive due to some dirt particles.
I took apart the carbs, bought some major rebuild kits from Amal, including stay up floats. cleaned them in my ultrasonic cleaner and got everything together again. I also cleaned the petcocks and tank, replaced fuel lines etc.
The bike fired up right away and after some basic tuning it ran pretty good. Exept for idle. After a run and stopping at a stoplight it dies.
Now, i tried to check my float level again, and i can see the fuel does not get the needle valves lifted to fill the bowls. even with the light aluminum ones. Does anybody else have this problem? I must say, the fuel tank level is low at the moment (on reserve). It can't be that there is to little pressure to lift the valves?
My test setup is: bowles attached to a horizontal plate, with their fuel lines attached, and the tank above. I can shut off the fuel supply just by inserting the needle valves in their seats, Gravity does the rest.
My carb is a concentric 930 MK1,5. It uses the larger needle valves from the MK2, but i also tried to use the smaller MK1 valves in combination with a custom valve seat. Without any luck.
The only solution i can think of is to eliminate the backlash of the needle valve somehow, so the needle opens immediately when the float lowers.
I assume there is no problem with a full tank, but i want my bike to idle smooth with a low fuel level too.
similar problems out there?
thanks,
dimitri
thanks,
dimitri
