Anyone know the allen size for the front spindle on a 02 Daytona? I don't have one big enough in the tool box and was planning on picking one up today. Thanks.
Discussion Starter #2
Found it
Did a search - looks like 17mm. I guess I should have done this first as opposed to wasting space on a thread. Note to self - search before you post.
It is a 17mm which was hard to find. I went to Lowes and purchased a bolt with a 17mm hex head and a couple of nuts the same size for under $2. I rant the nut to set the hex head half in and half out a 17mm socket and used that to remove the front axel. It worked like a charm
I ran out to Sears yesterday and found one for $10 - the last one they had. Used it last night. Probably won't be the last time it is used so I don't feel bad about spending $10.
