Hi
I have 2007 Speed triple. I'm not that familiar with electrical systems of bikes. I have a service manual for 2005 but I expected the wiring to be identical between the two models!?
I'm now installing an alarm system (not the OEM one). The instructions says that I need to cut the starter motor cable (the alarm wires go in between). I have looked from the wiring diagram that the starter motor to solenoid wire should be black (B). Instead of cutting that one I'm thinking of cutting the starter motor solenoid to starter motor relay wire (white-red, WR) because it is much more easily accessible (near the fuse box).
So my question is that if I use the white-red wire and install the alarm there instead of "straight" to starter motor - solenoid would this have the same effect??
My logic says that it should but I'm not sure so that's why ask the more experienced.
BTW, where the tarter solenoid is located? I can see the starter motor of course but where is the solenoid?
I hope someone has the answer, thanks in advance
