I am thinking of the British customs K&N Airbox removal kit..
My T100 has the AI removed, and Staintune reverse cone pipes. Will I need to rejet after I put it on? And is the conversion worth it? I have heard a lot of good reviews and it seems like everone has the stock air box removed. It seems like a simple bolt on, which I think I could do myself.
Nate
yes yes and yes.
easy enough to do, it really helps if you have a motorcycle lift, Sears sells them for under 100 bucks.
You will have to rejet, probably much bigger jets in fact.
I have that setup in my '06 T100 and I'm running 42 pilots, 1 shim on the needles (thruxton needles which came stock on our bikes), and 155 mains. I think I may need to go one size up on my mains.
Lots of power gained on the top end of the rev range, the bike screams to redline.
If you just cut up your airbox, you can buy pod filters, turnbuckle to support the carbs and a breather for around $100, and use the bottom half of the airbox to keep a tool kit.Plus not asll the hassle of getting the old airbox out
Stu: Good point. Overall time is about the same to cut-out the airbox as it is to install a NARK. But it saves you at least a couple of hundred bucks. Results are the same. My bike gained 10 lbs-ft of torque, and 16 bhp with the mod. I wrote up the procedure for the modifying the airbox, and have photos of the process. If anybody wants them, email me at [email protected]. Cheers, tommyturbo2
