1 - 9 of 9 Posts
I lost the plug that goes in the air box hole. Is there a place I can buy one or something that will work?
Just look for a grommet plug/ hole plug with the same diameter...Don't tell them what it is for, chances are they'll look at you with the Confused Parts Counter look...I hate that look...
I used the rubber sparkplug boot off my lawnmower.Filled it with silicon caulk,smeared a bit around the boot base,pushed it into the hole,then pulled it back up against the inside edge of the airbox. :-D
When you find a plug, I recommend using silicone or something else to keep it in place--they seem to have a way of jumping out without one knowing when.
Larry
1 - 9 of 9 Posts
