On 2007-01-03 16:11, GrayMitchell wrote:
Which is better for the Bonneville...K&N's or the Pods??? Are the K&N's really worth the extra $$$? Thanks.
Either of those filters will require quite a bit of air box modification....you are aware of that?
If you want an OEM replacement UNI filter, and a modified cover to enhance air flow, I'll pass on the slightly used, but PERFECT speciman sent to me from Scotland by JohnyC.
All I ask, is that in return, you send me the stock air filter cover off your bike, so that I can open it up for the next guy.
JohnyC started this, "passing it forward," and as best possible, I'd like to continue it.
Gray, the offer is on the table, if you don't want it, it will be there for the next poster. I would have used it myself, but received a K&N for Christmas from the S.O.
