The top tab on the air cooler that connects to the frame broke free, leaving a small hole in the top of the air cooler.
Is applying JB Weld to the air cooler hole to fill it up a safe bet? Or will the oil pressure blow it out?
Hey Rod, how you been. Ha, I did not query ebay with bonneville. $100 is not bad. New is over $500.
I applied a few coats of JB. I will let it set for a 24 hrs or so and then give it a try.
