1 - 20 of 20 Posts
I liked a spoke wheel but I do not like a tubed wheel. I am then considering changing wheels and at the same time wider rear wheels. Are there any options out there? New to the Triumph scene...thanks
I put an SE wheel on the rear and an America wheel on the front in order to not have to run tubes. Has worked great so far.
720921
Also a wider wheel would require a different swingarm as well as modifications to the countershaft to account for the wider wheel. Anything is "possible" with enough money and effort.
Thank you, are the SE wheel and America wheel the same size as the original? I can live with that too.
The SE rear wheel is the same size as the spoke wheel (17 x 3.5) and is a straight swap. The America front wheel is an inch smaller (the spoke wheel is 19 x 2.5, the America cast wheel is 18 x 2.5.) I made up most of the difference by going to a slightly larger front tire (the Bonnie front tire is a 100/90 x 19, I went with a 110/90/18 for the front.) Actual difference in diameter is less than half an inch.
Discussion Starter #8
where is a good online store to buy an inner tube for the rear of a 08 bonnie? thanks
Looks like EU640 per wheel or about $700USD at current exchange rates.
A bit pricey for me but I admit they look good. The only aftermarket alloys I've seen are $1200+USD each. Ouch!
Holy schmack those Canyon wheels are pricey!
Question about the wide rear wheel kit: How do they fit without a wider swingarm?
The price is pretty competitive with pretty much all other aftermarket wheels, especially since I believe he makes them custom order vs mass produced. Not sure about your 790 Bonnie, but on my 2013 SE there is a ton of room between the tire and the swingarm, chain guard etc. If you get wider than a 180 rear tire, you have to use the offset sprocket front and rear.
Discussion Starter #16
Somebody suggested I use the Outex tubeless kit from Japan on my original wheels to be able to convert them to a tubeless wheel. Not willing to spend $$$ at Canyon at this time. Your thoughts on this?
I sourced a pair of wheels from a supermoto wheel builder . Excel rims and Talon hubs a straight bolt on fit . I now run 120/70 17 front 160/60 17 rear , a 170/60 17 rear would fit easily . this also required mounting an alloy front mudguard beneath the fork brace that is beneath the original mudguard . Search the forum there are numerous people who have documented tubeless conversions . Cheapest option for wheel size change would be having your stock wheels rebuilt with rims of your own choice , my sizes allow a wide choice of modern radial tyres .
Discussion Starter #18
Somebody suggested I use the Ontex on my original wheels to be able to convert them to a tubeless wheel. Not willing to spend $$$ at Canyon at this time.
1 - 20 of 20 Posts
