Just thought I’d post how I mounted my aftermarket tach on my Bonneville for those interested. I was extremely pleased with the results, plus I know how fast the motor is turning over now. :-D
Here is a picture of the final mounted tach:
This is the same tach others have used before. I built the bracket out of 2mm aluminum I had laying around, using only a jigsaw, a cordless drill, and some time. The bracket uses the stock nuts that hold the speedometer in place to hold the tach. This works out well since the speedo has some vibration dampening due to the rubber surround, so the tach gets dampening too, plus the tach can be easily removed.
(Be careful if you remove the cap nuts on the back of the speedo as there are washers, why???, on both sides of the plastic cup on the back, you’ll have to take the speedo off completely to get these washers back on the inside of the cup – ask me how I know! Hold the speedo cup in place if you remove the nuts!)
Here is the bracket off the bike:
I also added a quick connect 3-pin deans connector inside the headlight housing so I could unplug the tach if need be. I soldered the blue and red wires from the tach together at the plug (see pic) – so only three wires need to be soldered in the instrument cluster connector in the headlight housing.
Quick disconnect:
-Green wire on tach connects to red wire (tach signal) on connector (3rd from left in photo)
-Red & Blue wires on tach both connect to red wire with blue stripe (instrument power) on connector (4th from left in photo)
-Black wire on tach connects to Black wire with short silver stripes (instrument power ground) (top left in photo)
These wires are all in the same row on the connector and can be removed from the connector to solder the extra tach wires in – makes for very clean installation. I don’t have a picture of the finished wiring at the instrument connector, but the tach wire is small enough to fit together with the existing wires in each of the three metal connectors.
Instrument harness connector:
This is a great addition to those with standard/black bonnies that are not ready to fork over the cash for the accessory tach. This install, to me at least, almost looks like it came from hinkley like this.
LS1
[ This message was edited by: LS1 on 2007-01-09 20:30 ]
Quick disconnect:
LS1
