Am thinking of changing the back end of the Adventurer (96 model) to a Thunderbird - better availability of luggage , better chooice of seats especially for the pillion - v importnat etc .
I have a rear subframe and a mudguard and a seat - what else will I need - I reckon a LHS pillion hanger and some billet to keep the Adv exhausts in place plus electrics - is that it , anybody else done this or similar?
I would say thats about it, you seem to have all the bases covered. Depending on options chosen you might need a new seat latch cable
Rear subframe swap
Here is few pictures. I do that swap for my ex-bike.
You must also pull out carbs & airbox because that upper frame bolt are drearily behind the airbox.
remove Adventurer subframe
which is a right one ?
install T-Bird subframe
and that´s it
@Ronkeli
Thanks for the pictures - unfortunately I have managed to get myself a mis described T/Bird sport frame which is not so good as it has different pillion hangers :-(
Back to the drawing board but you have done what I need to do Thanks
@Ronkeli
You can use it - youd just need to swap to the TBS exhaust system, this would actually be an upgrade as the balance pipe on the TBS adds a little more power.
