1 - 3 of 3 Posts
Along with the shock spools I added a pair of 1" frame clamps. I'm also fabricating a couple of seat mount/cargo spools screws.
Sorry for the large pix.
Looks good. Now,how about a couple Z shaped brackets that would slide into those plastic plugged frame rail ends,to be secured with simple jesus clips? 1/2" black iron gas pipe,from HomeDepot,slides right in and could be used as an additional rack setup for bigger than the seat loads. Or make them straight instead of Z'd and notch the plastic seat pan on each side,IF you're feeling adventurous.
1 - 3 of 3 Posts
