2020 Trident 660 Matt Black
Here are a few of mine picked up from my dealer in Charleston, SC last Friday evening......I've since swapped out the standard mirrors for bar-ends, and thrown on some black adjustable clutch and brake levers, replacing the stock aluminum ones, as well as removed all stickers and reflectors.
751527
751528
looks good. love those bar end mirrors. i also took the pillion pegs (or whatever they're called) off mine. the more space under the seat the better! planning to add any frame sliders?
Thank you. I’ve considered removing my rear pegs, but since I do almost all my own maintenance my bikes are regularly in and out of a rear stand, and this bike doesn’t have a lot of handholds in the back to lever it up, except for those rear pegs and the pillion strap. I may wait for someone like TEC Bike Parts to make a small grab rail to put in place of the removed rear pegs.
I was planning on getting the Triumph frame sliders, but I was ambivalent about the way they look. I’m waiting for LSL to a make a set for this bike. Had them on my Street Triple R and love their minimalist look. I had somebody push that bike over and they did their job perfectly.
I like it! I particularly like the shape of the tank. Is it a cover or is that the actual tank?
What you're seeing is actually a plastic outer cover. The actual - presumably metal - tank is underneath this plastic cover. The interesting thing about having this plastic cover is, if you want to, you can swap it out for one of the three other current color schemes!
