A-9s custom brackets for custom mini speedometers
35318 Views 112 Replies 19 Participants Last post by  D9
All I can say is WOW. He sent me 2 black brackets [one split for wiring,one solid] at no cost for the parts or the shipping. I used the split version since my wiring was already installed and it went on in minutes,nice,tight and secure. A very cool way to get rid of the bulky Triumph stuff and the perfect end to a crappy work day. :upthumb:
101 - 113 of 113 Posts
D9,on the twin bucket panel,could maybe a "speedhole" be cut between the cut outs to allow for the odo knob to pass thru,then rotate the speedo to the proper position? Probably only work on Thrux models though,because if I put mine any lower,I couldn`t see the speedometer when sitting. :-D
Terry,
Well, shoot... that explains it... oops...
rodburner -
I came this close to emailing you sunday and asking you to
check clearances for exactly that - a knob slot (does that
sound sleazy or what) - instead, went over to lox's house and put one of the protoypes over his speedo & drew the knob position right on the plastic.
What I'm thinking about is adding is a slot and then a second 1/8" retaining ring... slide the speedo through and then rotate, just like you said, but then, rotate the second ring into place... the ring would have a raised tab to match the gap in the slot... anyway, working on it!
But, may be moot as far as Bonnevilles are concerned - as you've pointed out, the little gauges are a good height just as they are - much lower could well be too low - other issue would be speedometer cable clearance - would probably have to move the gauges further apart...
It's all in the details...
D9
You said the shop broke the reset knob and is ordering you a new one. A new complete speedometer or a just a new reset knob? I think with the double gauge set up the gauges could be lowered all the way without speedometer cable clearance issues even if the separation between the two were not increased. The single speedometer centered however may start to hit the headlight can if lowered more. Awesome Thruxton Whitehurst.
THX - Next week the back tire will be a 170 - It iwll bew loward 1 1/2 inches - Bubs will be put on and the tank will be sent out to be nickled...
I was wondering if the Mike XS speedos were electronic or mechanical?
I think I may have found a speedo for Harley - but I have to be sure to order the right thing.
Whitehurst,you ARE gonna bring that to the Mods Vs Rockers Event Jan 13 /14th ,right ? lI'd ove to see the set up and say hey.
MikesXS speedo`s are mechanical [cable driven] Just order the right ratio. Mine is 2240:60.
Thanks allot - that helps... :)
I found a "Drag Specialties" speedo that will work. Exactly the same but without the tripometer.
Thankyou
Not sure if anyone's still interested in this thread- it's 4 months old, but I want to make some custom brackets for a tachometer- but not the mini one. I want to keep my regular sized speedo and get a regular sized tach that matches it, then make some brackets to install the speedo and tach right over the forks, like this:
My question is does anyone know of a source for tachometers of the same size as the stock bonnie speedo?
Granitsky -
Good to read your comment - you're not alone, others have suggested some brackets that do exactly as you've pictured, suspending the gauges apart, using the fork bolts like some of the older Bonnies... agreed, it would look cool!
Couple of things to keep in mind - choices of tachs & speedos for the Bonneville besides the stockers include minis, mini-mini's, some really cool high-end stuff, and whatever you can make work... :-D .
Question - are mini-gauges out of the question for the project? They look somewhat closer
sizewise and stylistically to the gauges in the picture you posted than the stock gauges do... let me know if you'd consider going this route, I may have a couple of these brackets left...
Meanwhile, back to the fork bolt-mounted bracket concept... one puzzle that has yet to be solved... the existing fork bolts seal the forks... because of their design, I'm not sure you could hold a bracket down with the OEM fork bolts
while maintaining a seal without getting into more involved machining of the brackets... there's fine threads, spacers and O rings under there... Loxpump has suggested drilling and tapping
a small hole into the top of the existing fork bolt and running a fastener through the bracket into that hole...
Say you had the custom brackets fabricated and had solved the sealing issue/fastening method... routing of the speedo cable would need to be
worked out, as of right now the position of the headlight bracket right under the speedo looks like it might not allow the speedo cable to connect. Are you ok with rotating the speedo CCW - 30 degrees or so - to allow attachment of the speedo cable?
FYI - new "lay-flat" bracket due out soon, uses stock tach, speedo & indicators... far different from what you're searching for, but may be
worth considering, here's a pic...
D9
I just wanted to use the stock speedo just because I like having the original mileage on there. I figured I could use mini's or something similar to replace it if I had to.
My idea for the brackets was to just make/have made a bracket that extends outward more toward the forks, but uses the stock 4 connection holes between the forks, sort of like the split brackets you have, but that extend more outward...
Ok, I get it now - thanks for the explanation! I hear you about mileage.
It's all doable, but considering the overall bulk of the stock gauges, I still think you might be happier with the mini's... no time to post further this morning, but I have some possibilities for you... more later...
D9
Is it possible to 'clock' the mini's like some car dealers do to their motors to make them appear as though they have done less miles?!
By the way D9 on that recent message you sent me, with the attached pics, how did you manage to get the speedo on without damaging the reset screw?
Have you changed your design? Because if they were black I would most likely go for it. Managed to find that tach on ebay, but currently waiting ofr XS germany to get back to me about stock availability for the speedo.
Not too bothered if the back lights are not quite the same, cos my stock ones are not exactly in unison either at the moment!
BnB,
This thread posted the original Generation I mini gauge brackets, no longer in
production, having been replaced by the Generation II mini gauge brackets, which allow full seating of the gauges, including mini speedos with resesttable trip odo on the upper left side...
Hope that clears any confusion.
Please see this post for pics of Gen II mini gauge bracket prototypes:
http://www.triumphrat.net/showthread.php?t=57199
D9
