Keef,
You nailed it - great observation, from someone who's obviously been poking around on this like some others in here...
The stock bracket bosses are the real obstacle - and it's a bit of a visual Catch-22... if you don't use the existing bosses, they'll just sit there an look funky, unless you remove them... if you do use the bosses, the choices seem to be either a push through solution like what I've come up with - or - a slick, thinner-gauge little bracket that uses the bosses but then makes a couple of tight, well managed bends to arrive underneath the
gauges - the second solution might look better than the push-through, but that's another project...
Another possible mounting point - again, probably visually better than the push-through solution - is to use two holes that are located underneath the upper triple clamp - you can see these holes in the reflection in the headlamp of the underside of the upper triple clamp if you look carefully - Lox seemed to recall these holes were used for windscreen fastening - a simple V-bracket might work splendidly here and get the gauges - even the stock gauges - further inboard and also lower - but thats IF you're willing to grind off the existing bosses...
Another possibility - using the lower handlebar clamp bolts - still would need to remove stock bosses...
Several posters have mentioned using the fork tube bolts for gauge bracket mounting points - I never had mine apart, so I'm not sure if that's a possibility or not - anybody who can shine some light here, please consider weighing in...
Couple of pics, courtesy of Loxpump, bosses circled in red, for anyone just joining the thread...
D9
D9
[ This message was edited by: D9 on 2006-11-20 17:08 ]
