Resurrecting a 2002 Speed Triple 955i following a long period of hibernation and neglect under previous ownership. Bike is now running and riding, starts with no issue, but suffers two running conditions that I am seeking some assistance with.
1. Engine idles at 1,600 - 1,700 RPMs at operating temperature.
2. Engine stalls following clutch engagement when coasting in gear.
Relevant bike information:
-Sagem ECU
-Lambda/O2 Sensor
-TORS Exhaust
-Map #10158
Relevant maintenance/repairs:
-Throttle bodies have been cleaned and synchronized using a Carbtune manometer
-Throttle position sensor has been reset with TuneECU and voltage appears in spec.
-Throttle cables have been adjusted so that throttle body valves close quickly and smoothly.
-IACV stepper motor was disassembled, cleaned and lightly lubricated.
-IACV vacuum lines were replaced with 6mm silicon lines, ensuring the blank port was not utilized.
-Reset adaptation following TuneECU guide for Sagem/Lambda models: neutral, clutch engaged, coolant temperature 80 - 100 °C, airbox temperature 21°C minimum, engine idling for 10 - 30 seconds
-Uniformly backed out each of the synchronized throttle body air bleed/bypass screws until IACV stepper position reached 35/36.
On the last step noted above, the idle began to increase more so I stopped adjusting as the screws were backed out quite a bit and the IACV stepper motor position had reached the upper value of the recommended range (30-35) at idle.
As both conditions remain, where would you recommend I look next?
As a side note, Target Idle Speed only seems to reflect a value on the list every 3rd or 4th time TuneECU is connected.
TuneECU via Amazon Fire HD 10 (Android) tablet:
-Sagem ECU
-Lambda/O2 Sensor
-TORS Exhaust
-Map #10158
