On my 00 RS on the engine case just above the neutral switch plugin is a little bolt with a brass crush washer under it. What is this? I have no manual with my bike and there is a small leak coming fromn there.
Help?
Are referring to the attachment in the upper right of this photo?? This is the rear side of the engine on the right side.
That would be the Cam Chain Tensioner.
If that is the part you are referring to, then the switch below it is the oil pressure switch (with the rubber boot)
