G
Guest
·Thank you to all who may respond-
I own a 1995 Daytona 900 and have no mechanical skills. Yes, you can laugh now. The issue I've been having is with cold starting my bike. It recently sat, without running/being turned on, for a two month period. When I tried to start it up, it wouldn't turn over. All my lights are working, and you can here the starter winding it's little heart out. I've been told that it may be the ignition coil(s). When I tried to push start the bike, it worked and the bike ran like it's supposed to. I even cut the engine off after riding for a short period and tried re-starting the engine...everything went according to plan and the bike fired right up.
Is replacing the ignition coil(s) the remedy to my problem, or is there something else I need to worry about? :???:
